Cable cutter, will any cutter do?
Northampton
I want to buy a cable cutter. I did a Google search on cable cutter, rather than looking at cycle shops.
I found that Scew Fix has a cable cutter for under £10 with good reviews.
The question is will any cable cutter do? Do I need cycle cable cutter?
subaqua
What’s the point
Leytonstone
yes any cable cutter will do but depends on your technique.
i use a scrap bit of inner when i cut outer and a scrpa bit of outer when i cut inner. my knipex cutters which i use in work as part of my day job as a spark work fine.
buy a decent quality pair.
there are some who say you need bypass cutters and fancy cycle specific but thats bonkers
All you want is a clean cut. Even cheap cutters will achieve this a time or two before they are not man enough. Since decent ones are quite expensive (Cyclo are around £20, I think) it may well be cost effective to use cheap ones for a one-off job. Just do not have an uneven cut nor any stray strands. They will cause mysterious gear-changing problems that have you fiddling pointlessly with the adjustment all the time, before you work out what the problem is!
Profpointy
You need a good cable cutter -.key word to look for is "piano wire" in the description. £10 sounds a bit cheap, but may be OK. Good pliers and cutter brands are Lindstrom (the Rolls Royce of pliers - I lost an awsome pair of Lindstrom heavy duty cutters - no longer.made so irreplacable), Elliot Lucas, CK - and good brands for tools.generally Facom, Bahco, Gedore.and a.few.others.
I'd not get a bike brand tool for a generic tool like wire cutting, nor allen keys.etc
slowmotion
Quite dreadful
lost somewhere
I 've got a pair of Draper Expert cutters that cost about £10, You can find them on Ebay and Amazon. They are excellent.
Deleted member 23692
I've got one of those and it's perfectly OK for cutting copper cable, but is useless on steel.
gbb
Peterborough
I cant see which ones you're looking at midlife....but if its the Forge Steel ones...id avoid.
We have a trade account with Screwfix and we've never hqd anything Forge Steel manufactured that was any good...in fact, its bloody awful stuff.
While I cant speak for the functionality of the Irwin ones which are £11 odd iirc, they will be far far better. I have some of their side cutters and they're fine.
midlife
I was commenting on the Park Tools pro cutters at Tweeks. :smile:
Shaun
Sorry, just noticed the OP is a midlife too lol
  • Like
Reactions: gbb
midliferider
Northampton
Thanks everyone for your replies.
With my extremely limited knowledge and experience of using any kind of tools, I will stick to a tool where it says cycle cable. I am now attending a bike maintenance course. This has really highlighted my lack of basic skills in using tools.
Park tool cutter sounds like a good one for that price.
SpokeyDokey
I use a pair of pliers, stick the cable twixt the little sharp cutting edges and then whack the plier jaws sharply with a hammer. Beautiful clean cut every time and cost nowt as I had the tools anyway.
