flake99please
We all scream for ice cream
- Edinburgh
I’ve literally abused bikes fitted with SKS mudguards without incident. Cobblestones will not affect the fittings.
Your LBS chap doesn't know what he is talking about imho. 700c mudguards will fit and I doubt the secu-clips will rattle free. If it were my safety at risk, I'd fit secu-clips every time.
The safety mechanism is on the stays. You can buy the SKS secuclips separately. For the price, I'd give it a go. They need to fit snugly and take some effort to release. You could return the Oxford guards and buy 700c guards if the secuclip is too loose.
Most 'guards come with a metal clip to fit the lower rear chainstay bridge. This has never worked well for me, it can rattle and come lose A quieter and more secure fixing is to drill a hole near the end and use a small ziptie. If your chainstay bridge has a threaded eyelet use that
I've used a cable tie to hold the front of the rear mudguard against the seat tube and a 100mm slate hook to support the tail end on the pannier rack. My ABS guards are for a 26" wheel and I'm using them on a 27.5 so I've had to make a couple of mods to keep them away from the tyres.I've also used the cable tie trick, and it stops the usual problem of either a mudguard hook bracket cracking and falling off, or a fixing bolt being vibrated loose so it's nut falls off! I would also recommend adding a bit of vibration damping at the chainstay bridge by wrapping it with some old tyre inner tube, or even using a small piece cut out of a really skinny section scrap road bike tyre. Mudguards that don't vibrate like hell give you a more peaceful ride and they last longer too.
I like my rear guard to go all the way down as far as possible to protect the drivetrain from road splash.I've used a cable tie to hold the front of the rear mudguard against the seat tube and a 100mm slate hook to support the tail end on the pannier rack. My ABS guards are for a 26" wheel and I'm using them on a 27.5 so I've had to make a couple of mods to keep them away from the tyres.
I heated the front one with a paint stripping gun just enough to change its arc and I've forced the arc out on the rear with the slate hook.
With the sort of unbreakable guards that @Lovacott (and I have got on MTB's) they are short enough that walking the bike stood up on its rear wheel is not an issue.
Dont worry about safety release guards.
I've had mudguards ever since I was a kid and I've never heard of a stick being picked up and wedged between the mudguard and tyre so tightly that it threw the rider off the bike.
Feel scared. Feel very scared! Seems a entirely sensible safety feature to me.some kind of scare marketing campaign?
