MissTillyFlop
Evil communist dictator, lover of gerbils & Pope.
Hello,
I apologize for the fact that my first post is so . . . personal. I need some ideas about how to deal with this and none of the Google searches I have done seem to really address this. For the past 1 1/2 years, I have been biking approx. 14 miles per day (22 km/day) and have been finding that I regularly get painful bumps on the outer sides of my labia. I usually wear cotton underwear and bike in regular clothing. I have a soft, foamy saddle. I don't know for sure that this condition is linked to cycling, nor am I sure what changes I could make to reduce the frequency of this happening, but it can be very painful and it takes a while to go away. Biking is my main source of transportation and I pull my 40 lb (18 kg) son behind me on a trail-along; I don't know if the added weight is another factor. Any suggestions for dealing with this would be most appreciated.
I used to get this - it's basically downstaiirs acne / boils caused by chaffing and also trapped oil in the skin. I found losing the panties helps very much and having a decent, ventilated pad down there and also if going a long way, some sort of chamois butter.
Also, i find wide saddles make the problems worse, as they hold the crotch of your shorts right next to your skin - I have one bike with a leather Brooks saddle (which has ventiallation holes - these aren't for everybody, but they work for me!) and the other has a specialized racing saddle, also with a little hole in the middle.
I also find that unless I get changed and shower straight after coming back from cycling then this and... um... other crotch-realted issued occur!
		 Hope you find a solution
