pshore
- Last contour N of Cambridge
*Ahem*
It was built as a shared use path, rather than solely as a cycle path.
The northern section has bridleway status and is used by horse riders too.
*Ahem*
I was reading about them on the Cambridge Cycling Campaign website and note that they are, at least partly, in response to cycle crime, as it's one of the largest volume crimes in Cambridge....so I don't think I was wrong to prioritise actually having a bike to return to as being a main criteria for what would get me utility cycling in a given area.
It might look like a dutch cycle path but it definitely wasnt built as a cycle path, its the maintenance road for the busway.
heres the youtube I'd seen from 3.30" there's 4 junctions where the "bike path" has to give way to side roads. Ok, after that its pretty good, but I only remembered the first bit.
Does it matter? Its a wide flat well surfaced route for cyclists away from traffic.
yes, because this busway track seems to be being used to discrediit cycle paths, the title of this thread is "build it and they havent come" and this wasn't built as a cycle path, as someone else has pointed out there was already an existing and shorter route commonly used by cyclists. As with all cycle facilities if they aren't direct, convenient and inviting to use then yes people wont use them.
Guess it's clear for Cambridge natives but I can't quite grasp the question. Are you wondering why people aren't commuting to/from work Saturday 1pm, and all the while road running in parallel jammed with cars is filled with bicycles? Or are you shocked by the number of bicycles on roads vs. off-road cycle paths where off-road cycle paths do not exist?
Not knowing anything about the Park and Ride, how many people come from/there to the centre on bicycle in the first place on average Saturday?
BTW does it go all the way to Cambridge Station ?
Go to http://www.openstreetmap.org/, and click on "Map key", which is bottom-left.Thanks. Is there a key for openstreetmap ? I can see paths (?) in shown in 6 different colours and it would be useful to know what they mean...
