Building A Bike Maintenance Toolkit
mjr
I am waiting for sales to buy a torque wrench. Any advice?
When you get one, keep it as instructed. I broke mine by leaving it not set to zero too often :sad:
Now I would like to store them nnicely. I have seen them hang on a board.
Is that how you all keep your tools?
The good tools get kept in nice cases or hanging on the wall (either individually or in wall-hung cases). The day-to-day ones (allen keys, couple of spanners, pliers, cutters, grips...) are in an embarrassing heap by the stove at the moment :laugh:
mrbikerboy73
Worthing, UK
Are Hollowtech BBs not compatible with anything more sensible, then? I've not had the misfortune to meet one yet.
It's one of those external ones, never had a bike with one before. I got the bike second hand and it's seen the hose a few too many times I reckon and it crunched a bit. Easy enough to change but you need the tool to do it.
Cubist
Still wavin'
Ovver 'thill
For HT 2 BBs there's nothing to beat a socket type with a half inch drive and cheatbar guide. you'll need a separate finger tool for setting the preload, but the socket type are leap years ahead of the semi-ring type....they are far less prone to slipping, and you can get a decent bit of leverage. Of course, a decent half inch drive ratchet is also a boon.....
While we're at it, Torx bits and a socket set adapter for use with a ratchet screwdriver and/or a socket wrench are also a great investment if you have rotor bolts, handlebar mounts or chainring bolts that need regular attention. Undoing and then redoing 12 rotor bolts with small Torx key is the stuff of nighmares.
Buy as many different types of 5mm Hex keys as you can. You'll need long, short, P-handle, T-Handle, bent, wiggly and at least two of each, 'cos it's the one you use and lose the most.
I use large sockets as bearing guides on a ghetto bearing press, useful for hubs and headsets, but they also double up for removing the nuts at the top of suspension fork legs, some milled flat, for when an adjustable won't do it. so far I have 34mm, 32mm, 28mm, 24 mm....it's as cheap to buy them singly as you need them, rather than buy a socket set meant for a professional truck mechanic.
Thin plastic tubing (windscreen washer hose) and a variety of syringes for brake bleeding.
A set of dental picks for removing the seal from a cartridge bearing to flush and regrease.
Loads of cable ties. In as many different sizes as you can find. ASDA of all places do really good ones for not much money.
Lubes, fluids and cleaners? Lithium grease, marine grease, coppaslip, threadlock, carbon assembly paste, GT85 and Isopropyl Alcohol.
A garage compressor for drying, spraying, but most importantly tubeless tyre fitting. Can't think how I managed without one.
Northampton
Regarding cable pull tool or what is known as 3rd or sometimes 4th hand, I bought a cheap one for £8 on E bay.
I find it very useful. But I admit that I am not very good at using tools. So anything to make my life easier.
Ajax Bay
East Devon
After reading the 'ball bearings' thread, an item comes to mind not listed above which I use regularly is a set of measuring calipers with a digital readout (for measuring eg ball bearings, seat posts, rims, seat tubes, handlebars, dropout distances, gear and brake cables and outers).
Ben Reeve
Ben Reeve
I am reading this with interest. I came here several months ago looking for a recommendations on a tool kit.
On the advice from here, I started to build it one by one rather than buying a set. Now I have acquired quiet a few.
Yes, I just bought some plyboard and screwed it into the wall of my garage. Then hammered in headless nails and hung up the tools
youngoldbloke
A syringe and blunt needle to apply lube is essential for me, and prevents waste. BTW, What are all these cable ties being used for?
Tim Hall
Crawley
Small ones for fixing computer cable to the leg of the front fork. A couple of larger ones get carried on a ride as emergency repairs for mudguards/racks/other random object.
Dogtrousers
Lefty tighty. Get it righty.
Reusable plant ties are also handy, for when you know you want it off again. Cutting ties off every time is soooo wasteful ;)
I carry some green plastic coated garden wire. This was a habit that I got into before cable ties were invented (or at least before I heard of them) and it's great for mending all kinds of things. Also a small roll of Duc[k|t] tape, or jeesusteippi (Jesus tape) as the Finns call it, because it performs miracles. But such bodges are for on the road rather than at home maintenance.
Cubist
Still wavin'
Ovver 'thill
MTBs need a lot of hose guides, and I don't like the clip on type...... So they're great as hose clips... Reverb hose, brake hose and full length cable outers.
One great application is to take the tension out of a rear mech while you thread the chain through. Cable tie it to the chain stay via the end of the cage, thread the chain and close the power link, then remove the cable tie. Simples.
