Buckled Rear Wheel
Jimmy Welch
Hi any suggestions welcome , I had a slight wobble on me rear wheel , so took it off bike to check , when I put it back on to start adjusting tension in spokes I didn't fully engage the axel in the drops and the wheel as well as being out in relation to the brakes was also catching on the rear stays which which made the balancing impossible when I realised my mistake I'd adjusted the wheel into oblivion , what's the next move here
Take it to your LBS and see if they can fix the buckle. Otherwise you might need a new rim and/or rebuild
