Black Sheep
- Rammy
It's not snobbery. Snobbery would be looking down on someone for riding a steel-framed 80s number while you're riding some super-lightweight carbon job.
My steel '60's road bike is about the same weight or lighter than a friend's carbon build
![Smile :smile: :smile:](/styles/default/xenforo/smls/smile.gif)
It isn't the price that defines a BSO ... it is the imitation of a bike ... cheap working maintainable bikes are fine ... ones which are made of extremely poor quality materials or design are BSO's.
cheap bikes with no suspension tend to be fine, some are heavier than others.
its when you start getting bikes with full suspension for £100 when, if you go into an independent bike shop they start at £800+ you have to surely ask yourself where they've cut costs to build a bike with suspension so cheap. the answer is it's built like a victorian station roof and budget components that will wear out quickly, the main ones being the bushings on the back end which will allow the rear bit of frame that moves to slop around all over the place making gear set up near impossible.
also, if you look, the pivot point on most of them is infront of the cranks, meaning there is no rear suspension when you are stood up / have weight on the pedals.
