Bryton Rider 50T vs Mio Cyclo 305 HC
migrantwing
Either of these units can be had with speed and cadence sensors for around £170. I had my eye on a Bryton, but now the Mio has caught my attention. Does anyone have any opinions as to the good and bad points of either of these devices, and has anyone used both units to make a fair comparison?
TIA
I have the bryton 50 - though not the cadence / hrm option which (IIRC) bumped things up to £260 [I regret not getting them now].
I have found the bryton a great product as a mapping device for pre planning rides - via the bryton website and for looking back on rides ive recorded.....
... BUT, don't expect much
[best to expect no help whatsoever] in the way of technical support from the company (though some have succeeded through facebook). In case you are unaware, i've been told Garmin are equally as poor with customer service - don't know nowt about Mio Cyclo sorry.
jasonmccullum
i bought the mio 305 3 weeks ago. and i love it
the gps is faultless, the battery lasts for around 8 hours, the only thing i dont like is the mount. i ended up buying a handlebar extender for £15 to place the unit in front of the bars
out of 10 i would give it 9. it was the best £170 i have spend on cycling equipment
if you do a search on my posts you will see the pictures of it
migrantwing
migrantwing
Thanks for the feedback, guys.
I'm edging towards the Bryton regards durability and overall looks, and seeing as it was my first choice before I'd even heard of the Mio. I did actually see your post and pics @jasonmccullum and this is what caught my attention regards the Mio.
Thank you for the handtec link, too :thumbsup:
Decisions, decisions!
Mickthemove
I have used a direct email to Steven at bryton and it is literally the only way to get anything sorted!
Mickthemove
At 170 inc hrm and cadence, the bryton is a proper bargain, but you would need to spend time getting used to it, garmin users sniff at them but for the same ish kit they are £200 worse off!
robotron
Being a Bryton owner (Rider 40) I can say that I'd advise you to at least check out their Facebook support pages (if you're a FB user that is) for some idea as to how many issues they seem to have.
I know that all user support forums show a skewed view but I've had numerous issues with the software & web side of mine, one of which has yet to be resolved after almost 6 months.
It reports all rides as being an hour out as it doesn't properly understand DST. There's no fix for it, and no setting to change to remedy it. Numerous users including myself have reported it but the stock answer from them appears to be to say "really? I'll do some test rides to check" and then ignore it and hope it goes away.
It seems like they're just waiting for the clocks to change rather than fixing it.
They've had numerous issues with different features of the website not working, which at one point was the only way of getting data onto and off the devices.
Even simple things like looking at your stats on the Bryton site can be a pain as (at least on my account) it still counts deleted rides, so if you upload a 0.001 mile test because you were playing with the device in your living room, it still counts in your total and messes up averages.
On the plus side you can export the files and import into Strava, Endomondo etc. to keep a proper record.
They're getting better, and it's a great piece of hardware, battery life in particular on mine is excellent and it's never missed a beat or recorded a dodgy position. It also finds satellites very quickly. Would I buy another Bryton? I'm not sure. They're certainly great value for money and now that Bryton Bridge 2 can export files without the website it does help to eliminate a lot of the issues caused by the flaky website.
How Garmin compare I couldn't tell you because I don't own one. Good luck with your purchase!
Downward
West Midlands
I have had the Mio 305 for over a month now. It all good and now Mioshare links to Strava so as soon as you upload your rides to mioshare it populates strava. Came with HRM and Cadence for £153. Easy to read colour screen, Navigation and the Suprise me function has now been updated so you can ask for routes to a certain POI on the map and it'll give you options with levels of ride difficulty too.
stumpy66
Lanarkshire
Any ant+ hrm and cadence sensor will work with it, i use my garmin hr and cadence sensor from my old edge 305 and it works fine
