rickangus
- west sussex
I have a B17 on a USE suspension post. I'm using flat bars on a touring bike but not too upright. I think riding position probably has a lot to do with whether a susp post will be of benefit. The more upright you are, the more noticeable a susp post will be.
I don't notice a huge difference between the USE and a solid post during a ride - it certainly doesn't bounce you around like a cheap full susp mtb would do - but what I do find is at the end of a long ride I'm noticeably more comfortable when I've used the USE.
If you 'concentrate' on the saddle end of things when you go over undulations, speed humps etc you can clearly tell the difference with a susp seatpost. Most of the time, though, you don't notice it which I think is a good thing.
It is important to get the correct elastomers for your bodyweight and if between weights I'd go for the heavier.
