Yellow Fang
- Reading
I thought some kids had damaged my Brompton. I locked it up outside a bowling alley. When I unlocked it, it felt a bit funny, and then I noticed someone had gobbed on it. On the way home the chain kept coming off, and I suspected they had bent the chainring. I tried knocking it back into shape, but it was a bit like that scene in Father Ted where he tries to knock out a small dent in a prize car and ends up crumpling the entire shell. So, I ordered a new chainring, which I fitted yesterday. Now I'm not so sure it was the chainring, because when I started cycling it this morning, there was a distinct wobble on the back. When I had a closer look at the rear frame, I noticed the bridge was broken. It seems to have corroded through. I'm wondering what I can do about it. I know you can get replacement rear frames, but an additional problem is that one of the bolts attaching the rear frame to the main frame has been glued in using thread-lock. A bolt had come loose and wouldn't tighten up, so the LBS recommended doing that rather than sending it off to have it re-bored. Maybe it's time to do this anyway.
. Well, there you go, I've always thought Brompton was an example to the rest of British industry.
