Most of the laquer is on now
Forks, triangle and stem have had 4 coats and I'm happy with the finish so they're pretty much done, just need some time and heat to cure fully. The main frame has now had 3 coats but the last of them bloomed in a few places so I'll keep an eye on that. With any luck the next coat will reactivate the last layer of lacquer enough to fix it, otherwise I'll have to sand it back lightly in a few spots
I'll try and stick the fourth coat on the main frame later after it's warmed up a bit in the house
To be honest there are lots of imperfections with the paint when you look up close but it still looks ace from more than about a foot away which is perfectly good enough for me
