Mostly, and because of design constraints I think, hub gears tend to have those large jumps I was attempting to avoid. Even "close ratio" ones aren't in my book. But I'm willing to be convinced.There are after market 8 speed hub options, Alfine and SA, but neither are cheap. Threads on here about them if you search.
Yep - I very rarely get past 20 mph these days although if there is a downhill with a following wind I can. Some 13 years ago I designed my current gearing so that I would spin out at 30 mph whilst giving me a bundle of climbing gears. In practice I nearly unscrewed my legs at 32.5 mph back in the day and did ride a 1km of 25% as designed. So I'm a fairly well calibrated rider and know my gearing needs. These days the 25% would defeat me so I've put a bigger cog on for my up coming tour.I have a six speed with S bars but reduced the chainring to 40t. This gives a good low for some of the nasty hills I tend to find myself on. Reduces my top speed on the flat to about 20mph but then I am never in too much of a hurry since this bike is used entirely for touring. Best investment I ever made bikewise.
Well, seeing as you mention it... YesHmmph - am I just a fussy fussy?
I'll put my hand up to that.Well, seeing as you mention it... Yes
Id think so. I have read about people passing out an IKEA dumps bag and putting it in the hold OR putting everything else in the hold and putting the Brommie in the overhead locker. If you're in business class, no probs.I'll put my hand up to that.
Thanks for the gearing advice everyone.
My current tour is complicated by flying back from a different airport from my starting one. I'd still need an airline bag or box for a Brommie tho' wouldn't I?
Sex on 2 wheels! That's nice.! The right shifter should be adjusted so your thumb fits neatly in the vee. Ergon grips are the way to go ...Just picked it up, very happy with it. I'm impressed with just how solid it all feels. Gears are, fun. Synchronising between the hub and the derailleur will take some getting used to and the right side shifter is very awkward and requires shifting my grip of the bar to use which doesn't sit well. Will see if it's position can be tweaked. And those handlebar grips..........
May also need to change to a longer seat post which surprised me as I tend to buy shirt trousers and still get them taken up!
Here are some pics.
View attachment 141878 View attachment 141879 View attachment 141880
Also picked up a new cage and bottle which will probably just be cable tied on for now until I can work up a more permanent solution.
Very much looking forward to getting it home and having a proper poke about.
Thank you!Sex on 2 wheels! That's nice.! The right shifter should be adjusted so your thumb fits neatly in the vee. Ergon grips are the way to go ...
Sure it's mudguard, not seat post? If you shove the seat post all the way down it can hit the ground.Oh, and is it common to not be able to role the bike on the transport wheels? It feels like the mud guard bottoms out on the ground rather than sitting on the small wheel on the guard.
