Fastpedaller
I have a 2007 superlight which (until last year) had covered zero miles, and is probably at about 300 now, so barely used. It's a 2-speed, and I'm looking at changing it to 3 (derailleur) gears. My understanding is the crankset will need to be replaced for 3 reasons 1) The current chainring is one-piece with the cranks 2) I'll need a narrower chainring in order to fit sprockets suitable for 11 speed. 3) The bb is ISO square taper, I'm ok with fitting a new JIS cartridge.
I'm happy to get a new chainset from Spa (and would also choose 160mm cranks) and maybe go for a double and fit a front changer (although unless there is a large chainring jump I appreciate it may result in 5 (or even 4) distinct ratios. I understand I can alter the 2 speed derailleur changer to give an additional central position. I have 13 and 16 sprockets (originally 12-16) but really want the middle gear, so would probably go 12/14/16 or 13/15/17 if there is enough clearance. Does anyone know if the Spa chainrings are ok for 11 speed chain, or can highlight anything else I've missed?
