broken chain
JohnRedcoRn
hope it never happens, but in the event of a broken chain in the middle of nowhere ; what kind of chaintools do i need to be carrying routinely ?
are we talking spare chain links and something to cobble the chain back together ?
and are there any other major chain catastrophes i need to be aware of ??
i have an intensive maintenance course coming up but i'm doing regular 10 - 40 mile rides so i should be able to do jobs like this.
thanks:smile:
Gerry Attrick
All I carry is a chain splitting tool, a spare pin or two of the correct type for the chain, and a SRAM removable link, although this latter is not strictly needed.
Assuming you have derailleur gears, then should a chain break, you remove the damaged bits and re-join the chain with a new pin. Best to replace the chain with a new one later.
JohnRedcoRn
JohnRedcoRn
thanks. so, chain splitter, spare links and spare pins?
i'm confused though - a chain splitter ; why would i need one of these if the chains already broken? is it to remove the broken bits from the chain ?
Because the chain will pull apart under the stress, and you'll need to take out the damaged bits, and also undo a new link to rejoin it.
It's worth practising beforehand. The first time it happened to me was on a dark and stormy night, 10 miles from home and 12 miles from work, where I had to go and do a short but vital job late in the evening. Luckily I knew what I was doing and was back on the road in a few minutes.
jassy-x
....I came across a cyclist at the side of the road a few weeks ago with a broken chain...luckily for him he had the chain splitter and spare links/pins to get moving again....which got me thinking....if it had been me I would have found myself freewheeling down hills and walking on cleets for the rest of the 20 miles home as I only carry tyre levers, spare tube, pump and multi-tool.....
...so do many of you guys carry the tools???
...if so, how many have been thankful for the fact??
...and on the other hand, have many been caught out??
palinurus
Velo, boulot, dodo
Watford
I carry stuff to fix a puncture, a multitool with a chainsplitter and some cableties. Most things can be fixed or bodged with those. At least if I had to walk 20 miles I could remove the cleats from my shoes. If touring I carry a few extra bits in case a crank works loose or a spoke breaks etc.
I've needed to use a chainsplitter at the roadside on two occasions in 20 years.
Soltydog
near Hornsea
Cheers, that's a top tip. I had bb trouble a couple of weeks back & thought i was going to end up walking 7 miles home, wouldn't have thought of removing cleats ;) In the end i managed to gently nurse my bike home
Mr Pig
I carry a chain tool, spare links and a quick-link.
I have fixed a chain on my mate's bike, he'd just fitted a new chain and I guess he hadn't connected it correctly. I've also been glad of the spare quick-link (SRAM power link it was) when the Power Link on my chain came undone going over rocky ground and I lost half of it. The spare link meant I was up and running very quickly, I actually spent longer looking for the lost link ;0)
