Right - just buy a powder energy drink - about £10 a tub, and if mixed without shoving loads in, it will last you - don't go spending for the sake of it.
A stitch hmmm - it's not food - much more common with running - here is an explanation......off the web but seems reasonable..... the thing about food shouldn't affect cycling as the body is static - not bouncing about.  With time and getting fitter, the stitch will go.... I find that breathing out very fast, when running, and repeating, helps - I never get it cycling though !
The reason for stitch is simple. The inner organs are hanging         from several ligaments, which, in turn, are fixed to the diaphragm, the         muscular "plate" between chest and abdomen. Liver, spleen, stomach, small         intestine and colon form a weight of several kilograms, hanging from the         diaphragm. The impact of every step forces the inner organs to move downwards.         Additionally, the diaphragm moves upwards on every expiration to force air out         of the lungs. This continuous up/down stress may cause a cramp in the         diaphragm: stitch. Stitch occurs most often on the right hand side because of         the liver being the heaviest organ, and therefore the one stressing the         diaphragm the most.
Should you suffer from stitch, the first (and best) cure is to         slow down or stop until the stitch is gone. If you do not want to stop, you can         try to press your hand onto the part of your abdomen where the stitch is, and         release the pressure on expiration. Repeat this several times.
An advanced method requires some thoughts about the reason why         stitches occur. You should try to synchronise your breathing pattern with your         running, and exhale when the foot on the not hurting side touches the ground,         i.e. when you have stitch in your right hand side, try to exhale when your left         foot touches the ground. You do not need to worry about inspiration - if your         expiration is right, your inspiration will be, too. If you manage to keep this         breathing pattern, your diaphragm moves downward at the same time as your         intestines, thus decreasing the stress.
