Spinney
Bimbleur extraordinaire
- Back up north
The loaves in my breadmaker (Panasonic) often come out slightly higher at one end than the other. It might just be a feature of breadmakers?
Tried it yesterday after your wonderful suggestion. All the mix fell out. After I cleaned up I re-read your suggestion. You didn't actually mean turn it 180 degrees upside down did you ?
Science is not boring !I find the rapid setting gives an uneven loaf but the normal setting is fine. If using the seed dispenser, that side of the loaf can be a little lower, I guess because heat escapes through the open flap.
I have an exciting life.
Mmmm, well I make either sourdough or use only a pinch of yeast in it (love the long bulk ferment & proof times) and bake the bread in a chicken brick as I can't steam my oven...![]()
Eewwww!I do mine in a dutch oven; a big cast iron, enamelled casserole pot. Lid on for the first 20 minutes to steam it first then lid off and down to 210C for the remainder. Works a treat to give an excellent crust.
By the way, why use commercial yeast at all when you're using a starter?
