Hi there
I'm looking for others' views/opinions.
The bike I'm referring to is a Bianchi Infinito CV Hydraulic Disc Brakes.
The front brake makes a squealing noise (its not a constant squealing when braking, its more like a short sharp yelp when I come to a stop).
Anyway, I booked the bike into my local bike shop who have said that they would look at it and do a brake service. This is what the mechanic has told me on the phone today:
The mechanic has said that the rear brake is fine but that the problem(s) are with the front brake and shifter. He has said that the front brake has contamination and when he was looking at the discs/pads, they were "glazed". He also said that the fluid is black when it should be pink and that the fluid is "cooked" (boiled up). He has also said that the master cylinder is corroded and that there is no pressure in the system. He has said that the "O" rings in the shifter are damaged and the whole shifter will need replaced.
