johnny mcgurk
- SW France
Can anyone offer any sound advice?I Am in the process of giving new life to a Dawes super galaxy 1980 ish frame but I have hit a stumbling block with the front brake.The brake bosses are only 55 mm apart and I can't find a brake set that will definitely fit. I originally wanted to fit v-brakes, which were no problem on the rear bosses(they are much wider) but on the front the arms are not even close to vertical. I then tried a pair of avid shortys (they were recommended for narrower forks) but I have the same problem.Undoubtedly I have not helped this by fitting 700 wheels rather than the original 28s??and a slightly wider 21mm rim to allow for fatter tyres.So, does anyone have any suggestions for a brake that will fit or, if not,Does anybody know what the original cantis on the Dawes tourers would have been.Any advice gratefully received.
