Hi all,
So fettling my bike today I see that the cap has come off the end of the rear brake cable and a couple of the strands have frayed. No sign of damage to the outer housing so I'm thinking it's a simple enough job, pull cable out, gently push replacement back in.
Right ? How do you stop the new cable fraying as its being pushed through? Assume I need to buy the right kind of cable - the brake levers are SRAM RED. I'll take the old cable out and take it to the LBS to make sure.
If I don't know what I'm doing should I just get the LBS to replace it ?
Sent from my iPad using Tapatalk HD
