I live in the uk. Im not sure which size i need. Also, i cant take the old pinch bolt out as its seized.
I cant take the old pinch bolt out as its seized.
Can't believe we've had 17 posts about a hole.
It's now 22
It's now 22
I tried removing the nut but it doesnt get loose enough to remove the nut
They say Birmingham,or tell us where abouts in the uk you are to see if anyone of us can help you
Will it go through from the other direction - to clear anything that might be blocking it.
What's seized, the nut onto the bolt, or the bolt in the calliper? If the bolt's turning with the nut, make sure the bolt stays pressed into the calliper so the square shoulder stops it turning whilst you remove the nut.
