I wouldn't attempt this without a bit of practice and access to the right equipment, Oxy/Propane is probabley best for home use, Oxy/Accetylene would be OK but is more awkward for home use (safety concerns / rental of cylinders) you would also need flux and the correct brazing rod, and as
@Yellow Saddle has pointed a longer brake bridge would be required, a clean and good mated joint is the key to success.
I think siver solder was used for 753 frames as the temperatue control was more critical, the cost of silver solder is probably why it is not used when cheaper brazing rods will suffice.
I can't see why tubing can't be re braized, frame builder/repairers do it all the time.
There is a lot of good information on line.
http://www.lucasmilhaupt.com/en-US/brazingfundamentals/properbrazingprocedure/
I'd take it to a frame builder.
