Globalti
There's nothing wrong with the line of that cable, it's perfect. You can go well over that torque setting because you are only compressing solid material inside the brake bridge. Put some grease on the threads of the recessed bolt and all over the bolt itself to aid future removal then tighten it so that the first part of the brake, which is effectively its non-moving "chassis", is attached solidly to the frame with no swinging from side to side. The Shimano pdf says 8-10 nm for that bolt and explains how to use that little bolt on the end of the "chassis" to adjust centring: http://bike.shimano.com/media/techd...0A/SI-8JC0A-002-Eng_v1_m56577569830746290.pdf
It's worrying that the shop mechanic doesn't understand this fundamental point about brake setup - is it a proper bike shop or just a bike supermarket?
