doog
- The beautiful south
I use mine on the turbo trainer..... Previously used it for running and road work on the bike but found too many variables interfere with objectives ie traffic / obstructions etc .
One point to note is your HR won't rise if your cadence is low, no matter how hard you pedal. You need to get your cadence up to 95 rpm for your heart to be used efficiently.
I use mine on the turbo as reference for how my body is feeling the effort.
You need to establish your own HRmax. That's your first step. It would be better if you could get more zones, but if you can manually adjust your zones, then set Zone 1 from 65% to 80%, Zone 2 from 80% to 90% and Zone 3 from 90% to 100%. Use Anything below Zone 1 for recovery rides and endurance training, Zone 1 try to avoid as much as possible (also known as no-man's land*), Zone 2 for SST and threshold training, and Zone 3 for anaerobic endurance and maximum effort interval training.
*Known thus because it adds little to your conditioning, but adds to your fatigue.
This is kinda quick and dirty, if you want to use it more effectively get a good book on HR training. One I like is Arnie Baker's Smart Cycling: Successful Training and Racing for Riders of All Levels
I got that book at Christmas and just starting to get through it. Some good workouts in it
When you say Zone 1 is no mans land and should be avoided, I've been using my zone 1 at 65-74% MHR as my base training which is quite a lot. Cant find the article I read it at the moment but will have a look later after work.
edit: Found the article and it says Zone 2 75-84% is no mans land?? http://www.cycling-inform.com/heart...ate-monitor-and-zones-to-improve-your-cycling
Try telling my heart that on ascending a 25% climb! The two times I have hit MHR have been after 5-10 minutes hard climbing then a 25% stint.Sorry folks in posting "One point to note is your HR won't rise if your cadence is low, no matter how hard you pedal." What I meant was won't rise to your max HR.
"Try telling my heart that on ascending a 25% climb! The two times I have hit MHR have been after 5-10 minutes hard climbing then a 25% stint. "
Interesting, so what kind of cadence was this at? Were you out of the saddle?
I can see that the original load would create a demand and thermal effects then the 25% would push it up a notch. If you were out of the saddle using your arms, shoulders and back you'd create a lot more demand than just your legs alone.
Hitting your max HR on a bike is notoriously difficult, doing it running or swimming is much easier because of the range of muscles involved. I've not met anyone who can get to max hr on a turbo without a good cadence so I'm curious about your case.
Also as you get fitter you will use less of your HR capacity for the same work, i.e, your heart gets more efficient. MaxHR and resting HR will change little.
Unless he means when you are fit. My rhr unfit, 75, fit 48, really fit 44.Sorry - don't agree. As you get fitter, surely you would expect to see a lower RHR?
