mickle
innit
- 53.933606, -1.076131
Cool.
Gas turbine control systems eh?. Would you say that L4S is a "momentary" logic signal which will go to a logic "1" when a unit START is initiated and all the start permissives, including sufficient L.O. pressure, have been satisfied. L4T is the logic signal which will be a logic "1" when any trip (emergency shutdown) condition is detected by the sequencing or application code, such as low-low L.O. pressure, or high-high vibration, or exhaust overtemperature. L94T is the logic signal which will be a logic "1" when a normal, automatic non-emergency shutdown is active and the unit reaches the point at which the fuel is to be shut off. In order for L4 to be energized (go to a logic "1"), L4T must NOT be a logic "1" (meaning there must be no active trip conditions detected), L94T must NOT be a logic "1" (meaning that a normal shutdown is not active and fuel does not need to be shut off), and L4S must go to a logic "1" (meaning that all the start-check permissives must be satisfied, and a START must be active, and all permissives to run the turbine must be satisfied).
Or what?
Or what?
