jay clock
Massive member
- Hampshire UK
Well done mods!
I don't use twitter but my husband does so that might be a possibility. I'll see what happens via email as they have replied.If no help is forthcoming from Boardman PLC how about trying to tweet Chris Boardman himself?
Glad you were not injured as a result of this failure. Fitting a replacement fork is not a complicated affair, you or hubby could do it yourself if either of you are a competent DIYers, if necessary, cutting down the steerer and press fitting bearings might be the hardest parts for a newbie and warrant a trip to a mechanic. Otherwise, you are just swapping the components over to the new fork. You can save the easy parts for yourself if you are looking to save on labour. As other's have suggested, boardman bikes may offer to replace the fork, just don't accept the same model for obvious design flaws!
Sure, ask halfords, but they are notoriously stingy, and they're are under no obligation to replace components from a 2014 model bike. I wouldn't trust them to do the work or waste a trip there unless it's on the way to something else! Go to a reputable independant bike shop for the parts and fitting.I'll probably ask at a Halfords to see if they offer replacement forks (as it was bought from Halfords near me in 2014). But I won't be surprised if they say tough luck.
Hmm, yes I wasn't planning on them doing any work as I wouldn't trust it. But if they offer to supply the forks then I'll take that up. I've got one a 5 minute drive away so will ask just in case but won't hold my breath. I have a good independent shop I will use for the workSure, ask halfords, but they are notoriously stingy, and they're are under no obligation to replace components from a 2014 model bike. I wouldn't trust them to do the work or waste a trip there unless it's on the way to something else! Go to a reputable independant bike shop for the parts and fitting.
not necessarily. i’ve had a new wheel on my cx comp when it only needed a new freehub. to boot, also a new chain and cassette as, apparently, it was easier to put a new chain on than swap the cassette to the new wheel...Sure, ask halfords, but they are notoriously stingy...
