cyberknight
- Land of confusion
Collected my Boardman comp today !!
WoW ! is all i can say fits like a glove , a lot lighter and faster than the virtuoso , still getting used to double tap but it it sweet !!!
Find the left shifter lever stiffer than the right is that normal ?
Specs..
Photo taken with cheap camera phone ...
Specs..
- Approximate Weight (KG): 9.16
- Brake Type: Dual Pivot Caliper Brake
- Chainset: FSA Gossamer compact crank
- Forks: Full Carbon
- Frame Colour: White
- Frame Material: 6061 Alloy
- Frame-: Lightweight 6061 triple butted aluminium frame with tapered headtube and internal rear brake cable
- Front Brake: Tektro R730 Dual pivot
- Front Mech: Microshift
- Gear Shifters: SRAM Apex
- Gears: 20
- Gender: Mens
- Handle Bars: Boardman alloy anatomic
- Headset: FSA Orbit 1.1/8 - 1.5 Aheadset
- Hubs: Formula 32 hole Q/R disc hub
- Number of Gears: 20
- Pedals: Wellgo alloy body fitted with toe clips & straps
- Rear Brake: Tektro R730 Dual pivot
- Rear Mech: SRAM Apex
- Rims: 700c Mavic CXP-22s black 32 hole disc rim with CNC braking surface
- Saddle: Boardman black with cro-moly rails
- Seatpost: Boardman 350mm x 31.6mm black alloy
- Stem: Boardman black alloy 31.8mm
- Tyre size: 23c
- Tyres: Continental Ultrasport 700x23c black
