Epic Kits for both MTB's - works a treat and follow the instructions ! I know it's hard to do, but follow them by the letter and you'll get 100% success.
Why is it hard ? - the vids I've watched looked fiddly but not difficult ?
Yep, that's the one.
Me too! What next... Effing Shimano Gears?When I saw the thread title I thought you were fed up with them 😄
"Bleeding Hydraulic Brakes"
My suggestion would be to get the Epic kit, it's solid, comes with plenty of mineral oil and works well. I'd also suggest getting the Shimano bleed cup - and if you don't already have one then the road adapter for it - Epic have these on their store anyway at a good price so you can buy it all at once.
That being said, unless you have a good reason to bleed your brakes then I'd leave well alone until you do, it's not a hard process but there's no point doing it unnecessarily.
Me too! What next... Effing Shimano Gears?![]()
Brakes dont need bleeding as a matter of course - Shimano use mineral hydraulic oil which last way longer than the DOT types as it is less prone to absorbing water. Before you attempt to do so fit new pads & clean the disk rotors. If you haven't changed them in a year then it is likely just pad wear or contamination. If you do have to bleed them then be very careful not to cross thread or overtighten the insert at the bleed port - they are quite fragile.Hmmm. I changed the pads about a year ago. But the breaks aren't performing very well again. I didn't do that many miles on the pads - so was thinking a bleed in order. Bike is 3 years old. Brakes haven't been bled in that time.
