Bike tyre v car tyre
Sorry, probably dumb question but...
My car tyres kepp pretty much the exact pressure over 1year + whereas my bike I am pumping them up every couple of weeks. I do roughly the same mileage and on the same roads. Obviously there are difference in the tyres and the weight distribution, but the valves don't seem that different.
Why is that?
ianrauk
Tattooed Beat Messiah
Rides Ti2
Bike tyres are pumped up to a far higher pressure the car tyres, double, triple the amount in a smaller amount of space so the air inside the tube is under far greater pressure to escape.
Jon2
It's probably the rubber being much thicker in a car tyre. The air escapes slowly through the thin rubber of a bike tyre.
tyred
Ireland
Your car tyre also has a hell of a lot more air pumped into it so the tiny loss over time will take much longer to register on a typical simple tyre pressure guage.
02GF74
if your bike tyre has a shraeder type valve i.e. car type then it is probably on a cheap inner tube. Cheap inner tubes ten to have thick walls so are heavy so they should nbot leak. Some lightweight inner tubes- and I habre only come across presta valved ones, ok, there may be shraeder too but I do not recall seeing them and certainly would not have been looking for them since I do not use that type of valve (queue post as to which is better: shraeder or presta!!) and they achieve lightness by using different thin walled material - the result is less weight but bein more porous, they will go noticealby soft after say 1 or 2 weeks.
so basically, what I think I am saying is if your shraeder bike tyres are going soft in that sort of time (1-2 weeks) then either you have a slow puncture are the valve is not sealing properly.
