For sizing a bicycle,
Measure your Standing Height, and take from it, THIS :-
The result is your 'Crotch height'' or 'inside leg' as many would call it.
The frame size you need is 2/3 of your 'Crotch height'.
EXAMPLE: Me.
Height 1725mm
Sitting height 905mm
Crotch height = Height - Sitting height = 820
2/3 x 815 = 547.
I ride a 54cm SWorks.
OK done that and my crotch height is in fact close to 33" two thirds of 33" = 22 " which is 56cm so I am on the right frame height bike. Yet almost everyother road bike rider I see seems to have way more seatpost showing than I do.
The lbs looked at all kinds of measurements and wanted me to have a 54 ,as soon as I sat on a 56 I knew it was right for me though I did opt for a 110 stem instead of the 120 standard one so maybe they were adding torso/arm length into the equation.The way I see it is I can adjust my reach by leaning forward more or fitting a shorter stem or moving the seat but I have no control over the length of my legs so the frame height HAS to be right IMHO.
This would suggest to me that from my observations most road riders are on smaller frames than they should be?? This cant be the case surely?.
This is my bike,I have done several days with over 8 hrs in the saddle with no ill efect so I think I can safely say that it works for me.
While on the bike fit subject if I can pick your brains a bit more Jimbo or anyone else if they have any thoughts.
At the moment I can reach the brakes in the drops but only just.I am thinking of rolling the bars down slightly to try to improve that, I intend leaving the stem flipped as it is now at least for the time being.I am reluctant to do anything drastic as the bike is comfortable now.
