Bike size help
lindsay612
Hi
I am a very inexperienced rider and looking to buy my first bike since I was a kid. I want a road bike to ride around in Manhattan which is very flat. I will not be doing a lot of serious riding and some days will ride to work. I am 5'10" and was fitted at my local bike shop on a 54cm bike. The bike I want to order online only comes in a 52cm and a 55cm. Which size would be better to order?
THANKS!
Spiderweb
Not So Special One
North Yorkshire
I think a 55cm would be more suitable, if you feel you are over reaching you could swap the stem for a shorter one.
It would be helpful if you could lets us know which bike you were sized on and which you want to buy as we could find geometry charts and make comparisons.
Deleted member 35268
Is the bike also available to try in another store somewhere locally?
What bike is it ?
The 55 is a closer number, and in my mind a 52 is a small, not a medium.
My Giant Defy is a Medium (54) and i am also the same height as you.
Crandoggler
Do you know which bike you were sized on? Best bet is to look up the geometry and look at the top tube length. If they're relatively similar, you'll be able to adjust the stem length to bridge that gap.
Either is sweet ride. The 6ku is very very cool looking.
Spiderweb
Not So Special One
North Yorkshire
Great! Thanks for all the help. I was leaning toward the 55cm because it was closer in size. I was fit on this set at free wheel
http://www.citygrounds.com/fuji/fuj...x3COuQJaPL9nPpYlqzQweBP2Asx31uzE8AaAuoY8P8HAQ
But I do not have a very large budget and it is too expensive for me so I was going to get this one
http://www.citygrounds.com/6ku/6ku-fixie-singlespeed-bike-nebula-black-3043
The 6KU has a shorter top tube than the equivalent Fuji so you'll be fine on the 55cm 6KU.
Great price and a cool looking set of wheels.
huwsparky
Llangrannog
Yep, I'd go for a 55cm also. I'm 5ft 9 and have a 54 and 55cm bikes. Both are fine for me.
