Ming the Merciless
There is no mercy
- Inside my skull
Oi
Have you been spying on me?
Being a snail we’d need 24hr time lapse cameras to see if you’re moving on your bike.
Oi
Evening all,
I'm looking forward to the spring when I hope to get some longer rides in as part of touring programme I’m cooking up (I’m a bit of a forward planner 😀). I’ve done some touring/bike packing in the past, but really don’t get on too well with a loaded bike. My plan is to drive somewhere interesting then go on some long loops back to a campsite - I’m looking at 80ish miles a day, with a nice lunch stop. I’ve done that sort of mileage before but not regularly. So, my question ……… is a good bike fit a good bike fit regardless of distance, or are there tweaks you can make with saddle height/ spacers/stems etc etc to make the miles pass a little easier. I’ll be on a Planet X pro carbon - it’s supposed to be a bit of an all rounder but with a steer to a more ‘racey’ bike (I’ve already replaced the stock 25mm with a set of 32s which just about fit).
cheers all
You you'll be fine!
Do 32mm tyres really fit! Wow!
I'd choose a more comfortable saddle if your current one is a bit racey? Turbo or charge spoon??
Getting out the saddle helps on steeper uphills or coasting down hills.
Also doubling up the bar tape will help too.
If your a confident rider you can ride with your hands resting on the bars or even a puppy paws position.
Evening all,
cheers all
Evening all,
cheers all
Yes, provided you've setup your bike primarily for comfort.is a good bike fit a good bike fit regardless of distance
The real pro move is to do lots of core exercises for months or years before doing long rides which helps prevent sagging into an uncomfortable position after many hours.
There's a sliding sale from comfort to aero, so people doing crit racing or TTs may have a position too aggressive to hold for a whole day - almost everyone goes for a comfortable endurance fit though which will be file for all use cases.
Adding spacers will make the position less aggressive, but that doesn't mean it's more comfy - there'll be more weight on your saddle.
The best thing is to change up your position every so often by using the drops for a bit, standing etc, or doing things like a cat-cow yoga stretch on the bike to give your back a rest.
Well thanks all for your thoughtful replies. I’m planning on taking it at a fairly leisurely pace, I’ll give myself 8 ish hours with a decent lunch stop and if I happen to stumble across a nice pub on route …… who knows!
I guess my main challenge will be maintaining that for a few days as opposed to my ‘one off’ type rides of that distance. I’ve already swapped out the stock saddle for a fabric one (seems similar to the spoon). I might take a couple of spacers to have a fettle with, but it seems the message, loud & clear, is that I may need the tweaks rather than the bike!
Thanks all for your usual helpful comments👍🏻
