Hi, I’m trying to fit an abus granite 540 U lock.
I’ve a Trek sport 2 that has an oval top tube.
Anyone know if a lock or bracket I can use that will clamp around the to frame cross bar ? It’s oval/flattish.
I have the 440 brackets etc but they only fit outside on the rear frame or skewed if I put it on the vertical post (the lock is long for the post). I have the other clip on quick release fixing, but again, it’s not a wide enough diameter.
Any suggestions for a bracket that will keep it central from the top tube?
I’ll change locks too if there’s another maker.
