Tires: Kenda Cross 700x38C
Brakes: Tektro, aluminum V-brake
Rims: Alex ID-19, twin-wall, 36 hole
Fork: Alu fork with Cro-Mo shaft, 1 1/8 "Ahead
Chain: KMC Z410RB, for hub gears with Antirostbesch.
Crankset: Truvativ 5D single chainring, 42T.
Handlebar: Bocas riser bar, 620mm width
HR hub: Shimano Nexus Inter 8, without withdrawal, 36 holes
Hub front: aluminum sealed, 36 holes
Pedals: Wellgo Alu
Frame: aluminum 6061 T4 / T6
Saddle: Bocas Cross
Seatpost: Bocas Post, 30.2mm
Shifters: Shimano Nexus 8-speed, twist grip
Spokes: stainless steel
Derailleur: without
Stem: Bocas Ahead Stem, 6 °, 1 1/8 "Ahead
Headset: FSA No.10, Ahead sealed, semi integrated 1 1/8 "
Brake levers: Tektro, aluminum V-brake lever
Crank lengths: 175 mm
Bottom Bracket: Cartridge Bearing
Weight Kg approx: 12.5
Extras: 8-speed Shimano hub gears, aluminum fork
Number of gears: 8
COLOURS: Matt Black
Frame Shape: Diamond
Type: Cross Bikes
Wheel size: 28 inches
A 2007 bike, value: £90 - £100
https://www.gumtree.com/p/bicycles/bocus-city-x-hybrid-bike./1163054881
