Deleted member 23692
Yup plenty - it's tool-less and infinite thnaks to the knobs on the back ofthe support armsHas it got any height adjustment?
https://www.mygearup.com/lean_against_the_wall_bike_racksWhats the brand name of the rack you have ?
I think i have seen this in amazon its £99 a bit priceyYup plenty - it's tool-less and infinite thnaks to the knobs on the back ofthe support arms
Cheaper than moving house thoughI think i have seen this in amazon its £99 a bit pricey
True, but if you saw the two versions they make side by side, then £100 is a bargain for one that sturdy, compared with £60-7 for the cheaper one that feels like a giant paper clipI think i have seen this in amazon its £99 a bit pricey
Presumably you don't store a steel tourer or an ebike on the upper rung.I had one of those, and it was pretty flimsy and wobbly with just a road bike on top and an XC bike on the bottom: both of those were well within the max loading. I sent it back the following day and exchanged for it the tougher version with all it's box section loveliness...
I've got two of them now and all four of my bikes take up the footprint of just 2
https://www.ebay.co.uk/p/1405059774...WW_GWtNpN3znic4dLThovEIovjxUvIGxoC0ZoQAvD_BwE
No, but you can drop the lower arms down so supports the bike with it's wheels on on the groundPresumably you don't store a steel tourer or an ebike on the upper rung.
What kind of studs ?
You can also find where the studs behind the plasterboard are and attach the hooks there
Possibly at cross purposes he is referring to the wood that the plasterboard is mounted against, known as studding, or studding wallWhat kind of studs ?
Alternatively...
Timber wall studs are generally 16 inches apart in UK walls. Measure 16 inch / 400 mm increments from room corner to where you want to hang stuff and drill a few fine holes till you find the stud (upright wooden bearer on which plasterboard is fixed).
I have no idea of how to detect itPossibly at cross purposes he is referring to the wood that the plasterboard is mounted against, known as studding, or studding wall
