HobbesOnTour
- España
For what it's worth this is the best advice in my book
By the by if your current MTB has MTB tyres simply changing the tyres for more road friendly smoother ones could have a big impact.
You can count them on your bike now to give an indication of what might be useful on the new one - but only an indication - wheel size, crank length and even tyres can have an impact.
For more info read here:
https://www.sheldonbrown.com/gear-calc.html
The best advice is sort out existing bike, work out what teeth it has and see if you need anything lower than you already have when you can actually use the granny (small) chain ring.
So would one where you can use the full gear range!A lighter bike will be easier up hills.
I know it's very, very unsexy but a bike maintenance course would be a good alternative. You're new to cycling and a whole world of opportunity is opening up. A basic understanding of the principals of how bikes work would be invaluable and save money in the long term. You could build the perfect bike for you!m,y wife is buying me a new bike
Basically I just want a new bike
Simply, the lowest number of teeth on the front and the highest on the back is the easiest to climb on.should I look for in the smallest/lowest gear cog, to facilitate easier hill climbs?
