BianchiThe Emonda may not be the right bike as others have said. Do the shop stock other brands?
If you really want to be racey a 120mm stem on that could work. All the pros deliberately size down to save weight & you can still stretch out & get low.
Forget the sizing charts.
If your current bike is comfortable, just measure the relative positions of the three contact points - bars, saddle and pedals or bottom bracket. Then with this info, go and measure the bikes you are testing.
The only other consideration is stand over height. You should be able to stand, with heals on the ground, without the cross bar doing damage.
Good luck
I bought the previous model Emonda in 2020. Mine is the slacker H2 fit. Like you I'm 175cm, though I have a leg length a little longer than you. I bought a size 56 since it was the only bike available at my at my LBS at that time. I was riding it with flat pedals and trainers. The bike felt too big. I solved this by cutting 20mm off the seat post and accordingly 20mm off the seat cap. It was a straight forward job that took just a few minutes.
Being shorter in the body than you, and probably a little narrower across the shoulders, I felt the bike was a little long and the bars a little wide. I bought new Bontrager bars that reduced the width by 20mm and the reach by about the same ( and cost just £30). I then had a bike that I could fettle with saddle position etc and was able to get comfortable.
Subsequently as I've got used to the bike, I've made the change to clipless pedals and shoes. This has meant that I've put the saddle up by the 20mm that I cut off in the first place. I also found that moving the saddle forward so that I sat more directly over the cranks meant that I again increased saddle height. I then changed my saddle to an SQLabs 612 (excellent) which has helped keep my position on the bike more in one place.
I've measured my frame and weirdly it comes out between size 56 and 58. Being older I will guess that I have less flexibility than you, making the H2 fit better for me.
Based on my experiences along the way, I guess my advice is to get a professional bike fit before doing anything else. Failing that, maybe try concentrating on moving the saddle fore and aft before concentrating on saddle height, and try riding the bike with a clipless shoe, pedal set up before deciding.
The Emonda is a great bike. Trek quality and warranty seem to be one of the best in class and their new threaded bottom bracket set up is much better than the previous BB90 ( though it is a little heavier as a result). I've upgraded my bike's wheels and tyres. The original budget Bontragers items are well made, but they are heavy and the Formula made hubs they are built on are poorly sealed, leading to frequent maintenance.
The Emonda will make a good friend - mine certainly has become so.
Thanks for the lengthy reply! I did ask about chopping off a small part of the seat post on the 54, but I was informed by the sales assistant that doing so would invalidate the lifetime frame warranty.
But I am interested to see the chopped seat post and chopped seat mast. Can you show some pictures of this please? or is there a thread?
Spending north of £2k on a bike you have to chop a bit off the frame in order to make it fit you and invalidate the warranty in the process is the very definition of madness. Just buy something that can be made to fit the rider without having to butcher it.
Giant in particular, offer bicycles with one piece frames where the seatpost is cut at the top. Cutting posts in order to allow correct seat height isn't unusual either (it had to be done for my riding partner on hers)Spending north of £2k on a bike you have to chop a bit off the frame in order to make it fit you and invalidate the warranty in the process is the very definition of madness. Just buy something that can be made to fit the rider without having to butcher it.
Nah it's just you.It's utterly bonkers. Steel frame, round seatpost, clamp at the top. Loosen clamp, raise or lower seatpost, tighten clamp. job done. The people designing this modern carbon stuff are just having a laugh!
