Millzy
- Trowbridge, Wiltshire
Ok, I bought my Specialized allez 18 last year for a charity event that basically never happened. I also used it for commuting the 11miles to & from work every day, which I'd like to do again. Trouble is, it's a bit worse for wear at the moment....
I work at the top of a big hill in Warminster, when cycling up it (obviously bits were under strain) the bracket that the rear derailleur attaches to snapped, sending the derailleur flying into the rear wheel, bending spokes & the derailleur cage (the rear wheel was also buckled but I doubt it was the cause of this incident...). I took it back to the shop I purchased it from & they replaced the bracket.
I bent the cage back into shape & re-fitted the chain. Ever since this incident, the gears click/crunch as if the chains missing the teeth on the front cog & the chain keeps snapping!
I haven't used the bike since as the constant crunch/click/snapping chain & the turning weather. now it's warming up again I'd like to start using it again!
Basically (Yes, there is a question here somewhere!
), any idea's what it could be? Or should I jsut bite the bullet & replace the rear derailleur, chain & buckled wheel?
Also, if I wanted to upgrade from the Tiagra set it currently has to a 105 set, what other bits would I need to get to make it compatable?
Thanks in advance
Thanks in advance
