karimali831
Hi,
On my Saracen Mantra bike I changed the gears to gear 1, the chain then went behind the cassette, the chain then became stuck forcing the gear part, I think they are called "derailleur pulley" and "rear derailleur" to bend all the way to up to the center of the wheel.
The derailleur pulley (shown on the image below, circled blue) got stuck on one of the spokes of the back wheel, I had to force bend it back into shape but by then it just snapped off. I did that because I wouldn't of been able to move the bike unless I picked it up of course and I was hoping to bring it back into place. The derailleur pulley is now disconnected, the chain still on it but that is it. Also, I need a new headset as this one has cracked.
I'm bringing it to Halfords tommorow for repair. Any ideas how much all this will cost? I'm still under my 6/12 month warranty also.
Summarize:-
Derailleur Pulley -Completely disconnected, the chain can not move round as one of the sides of it is bent therefore I will need to buy a new one. Metal one this time.
Rear Derailleur -Bent back into place, gears are still function as tested. Not sure though if anything is damaged. (Seems ok)
Chain - Full grease, partially rusty. When I'm at a particular gear, the chain will trip somehow when I push down onto the pedals (hard) Not sure if GT85 will do the trick otherwise it may be better to get a new one.
Headset - Cracked. The bike will rock fowards when I apply the front brakes.
I'm assuming when I was on gear two, the chain was at its toppest of the cassette and when I went up to gear one, it went behind it. Perhaps something was too loosen or too tight.
Thanks for advice.
Summarize:-
Thanks for advice.
