Big ring fever?
jimboalee
Solihull
buddha said:
I got the geared bike out 2 days ago (I've been riding s/s for the past 6 months ish). Firstly, for some reason I was in more pain than usual. And I'd 'forgotten' how to spin up a hill in a low gear - it just felt wrong. Though spinning a high gear on the flats and descents was easy.
Are there any lessons to be learned?
Davidc
Somerset UK
I hardly use the big ring, even now I've lowered the tourer's gearing.
I find I use the middle one most of the time (32 with an 11-32 cassette) and really only need the big one (44) going downhill with a following wind.
With some very steep hills round here including a number of 1 in 3s I do sometimes use the 22 chain ring. I'd be quite content with a double with 22t and 36t instead of the triple, and may look into it when and if I wear out the present rings.
jimboalee
Solihull
Erm... 44T is not a 'big ring', its a medium sized one with a small ring and a teenie-weenie ring next to it.
My new bike has a 42/34/24 chainset and the chain is on the 42T exclusively.
I have had a recce of the 34 ring but the 24 ring hasn't been oil smudged yet.
There is a 20% hill in Redditch. I can get up it on a 30x25 700C sports bike, and I'd like to know what the 24x32 feels like under load, so I'm off over there Friday maybe.
My favourite carpark with its 25% spiral ramp has been demolished.
33% hills are 'walkers' in my book. The speeds are not dissimilar, so why waste energy with all that balancing act stuff?
Davidc
Somerset UK
My new bike has a 42/34/24 chainset and the chain is on the 42T exclusively.......
Depends on the rider whether it's big! You're probably stronger and younger than I am, the effects of time passing are a bit depressing!
With my bodily state (and age?) it's as big as I can sensibly use.
Bigger rings were OK in my youth, when I could apply real force at lower cadence when needed but now I get on better with less force more often, a higher cadence.
There was a time 30 years ago when I rode up 33%, and stretched chains, but I'll agree now that anything steeper than 20% is really a walker, though I'll do short stretches of 25%. I find that if I tackle something too steep it knackers me to the extent that I don't enjoy the rest of the ride as much as I would have.
The 32 middle ring of the present chainset isn't quite high enough for me not to use the 44, but when I had a 38 with a 48 largest ring I don't think I ever used the 48.
Edit: Should have said that I reckon any speed lower than 3.5 mph means it's more sensible to get off and push.
