Hi All.
My new bike includes the dreaded Presta valve tyres !!!! I have a phobia about them I think
and have changed them to Schrader on my last two bikes..... I can't on this one though.
I have a Beto track pump with an adaptor in the "lock" switch which I am sure is for use with Presta valves.
Only one end of that adaptor will fit into the end of the pump when it is is the open position and then locks in when you close it which is fine.
As the adaptor is solid plastic though I am failing to see how it is going to grip the Presta valve when you pop it on if that makes sense. What I am saying is how can the pump grip the valve when there is solid plastic between the lock "squeeze" of the pump and the Presta valve or am I missing something obvious here?
Cheers
and have changed them to Schrader on my last two bikes..... I can't on this one though.I have a Beto track pump with an adaptor in the "lock" switch which I am sure is for use with Presta valves.
Cheers
