TomHenshore
Regular
- Shropshire, UK
Ah, sadly OsmAnd doesn't have all the functionality on apple devices that it does on Android. No routing features, it's just a big map!
ridewithgps is easy to plot a route with and gives you satellite views as well and the app works well on an iphone.Ah, sadly OsmAnd doesn't have all the functionality on apple devices that it does on Android. No routing features, it's just a big map!
Plot a route on your cycling route website of choice, for example bikehike. With Osmand I've found best results if I turn off the "follow roads" option. You'll end up with a series of straight lines going from point to point. If you put those points at key junctions so much the better.Ah, sadly OsmAnd doesn't have all the functionality on apple devices that it does on Android. No routing features, it's just a big map!
Sorry. I didn't spot that your phone is a prisonerAh, sadly OsmAnd doesn't have all the functionality on apple devices that it does on Android. No routing features, it's just a big map!
Damn. Reread your answer. Ignore wot I wrote.Plot a route on your cycling route website of choice, for example bikehike. With Osmand I've found best results if I turn off the "follow roads" option. You'll end up with a series of straight lines going from point to point. If you put those points at key junctions so much the better.
Export/Save as gpx.
Load gpx onto your phone (you may have to put it in the Osmand tracks folder)
Run Osmand. Click configure map, select GPX track, pick the relevant track.
Click the arrow button, which generates turn by turn instructions. Say Yes to "Do you want to use the displayed track for navigation"
Click "go"
Listen to the voices as they tell you where to go.
I've no idea what they looked like on the map, I have (well had) route blindness riding from Dartford to Greenwich when being dropped off at my wife's works to then commute in. The situation wasn't helped by the fact that I'm always anxious about time elapsed commuting in, I rarely have oodles of wibble around time.One of the best things about http://cycle.travel/map is that hard-top routes are solid lines and rough stuff is dashed and it weights them in a way that works for me. Some are wrong but it's fairly easy to edit openstreetmap.org to change them.
Unsurfaced junk and motorist-jammed booby traps are both excellent reasons for using a satnav. Avoiding long detours after you're tricked into a booby trap is another one.
Hah! It's not like I've ever led a group onto the wrong side of an A road... oh, waitGoing on a group ride is better though - let someone else navigate and you can grumble gently at them when they get lost!
Hah! It's not like I've ever led a group onto the wrong side of an A road... oh, waitbut that was only the once and now I'm less worried about appearing confident, I double-check the satnav if in any doubt after the spoken direction!
But if it's when they get lost for your group, then shouldn't we volunteer you as a new wayfinder?![]()
What happened to old fashion signposts? Have they all been removed in the name of progress so that we all need gps wherever we go?All you need is the name of the places you will go through and anyway, you are only going 25 miles away from home, not hundreds. Enjoy your ride and don't worry .
That doesn't even take into account little country lanes where there isn't any signage in the first place.
Hi all,
Next Saturday I've planned for a mate and I to ride a route I've planned that's just under 50 miles. I've had training in route planning in the past as I'm a qualified ride leader, but I've never actually planned a route where i'm unfamiliar with the roads before...
The roads are all decent b-roads, most of which happen to be on national cycle routes anyway, but my question is what would be the best way to navigate when on the bike...? Are there any decent Apps out there that can act as a cycling-sat-nav? Would just simple route cards hanging around my neck be enough...? What are your experiences?
I'm all up for an adventure and getting slightly lost, but I would also like to get home for dinner...
Thanks in advance :-)
These are the best kind and the reason I follow a route in the first place. I know all the A and B roads within miles of me and most of the C roads too. I like to plan a good new route each time I go out. I guess the fact that I work for a mapping company means I love a good map, so the route planning is fun and not a chore.
