Best thing to clean rims
Colin_P
There are two things I use;
The first may sound completely counter intuitive but WD40 cleans the aluminium residue off the rim and stops squeeky squeekage.
The other is an automatoive brake cleaner aerosol, about £3 odd from a motor factors. Don't get it from halfords theirs is about £6!. Use it on a bit of rag / kitchen roll to wipe. It is also very good for washing / rinsing any grit out of your chain but needs a bit of time to evapourate before you re-lube the chain.
Of the two, WD40 is my fave, sounds bonkers I know but works!
ColinJ
Puzzle game procrastinator!
Baby wipes clean anything - I don't know why I didn't think of using them! :smile:
Apparently, they are pretty good on babies too, but I do not intend to put that to the test! :laugh:
KneesUp
KneesUp
That does sound like something I'm unlikely to try, but thanks.
(Surely it leaves a slippery residue?)
Mrs M
Aberdeenshire
I use industrial wipes from Makro, usually have some in the shed.
They are strong and quite large and are great at removing all kinds of grease, etc.
Stu Smith
Lancashire
I use the brake cleaner after my chain as been left to soak in a tub of diesel ..A wipe down with a clean rag then a liberal spray with the brake cleaner and the diesel and dirt disappear like magic leaving the chain like brand-new..
raleighnut
That's fine if you then immerse it in oil, I used to boil mine up in SAE90 rear axle oil then hang it up using a pipe-cleaner threaded through the chain and hung on a nail in the shed to remove the excess. Chain saw chain oil is better IMO.
Shut Up Legs
Down Under Member
If your wheel rims need an occasional extra-thorough clean, you can use one of these: http://www.chainreactioncycles.com/au/en/swissstop-swissclean-rim-cleaner/rp-prod42618
I don't recommend using them regularly, though, because it's hard on your hands and wrists. I don't think there's really any easy way to use these.
Donger
Convoi Exceptionnel
Quedgeley, Glos.
I've just chucked out a half bottle of Austrian "Stroh 80%" Inlander Rum that has been confined to the garage for years as it was so strong it was undrinkable. I bet that would have done the trick....... I'd leave the rims to cool down a bit at the end of your ride before applying, though, or you might have an inferno on your hands.
Fubar
Baby wipes - I forgot that I'd bought a big bag from my local market! Hand on, I'll go and test them - the braking on my Basso was a bit iffy on the last ride so I think the rims could do with a scrub ...
Yikes - good tip! :eek:
Also good for getting all the crud off your chain, cassette, etc - everything!
compo
Harlow
I just use very dilute washing up liquid and a green pot scourer then rinse off with clean water. Gets the rims lovely and clean.
Shut Up Legs
Down Under Member
So you'd have this, but on a bicycle?
KneesUp
KneesUp
That's just a big rubber, isn't it? I did actually use one of my daughters rubbers to clean the rims on my other bike, thinking about it. It was flower shaped. I wonder if it's still in the shed ...
Shut Up Legs
Down Under Member
Essentially, yes. As you use this stone, parts of it come off, taking rim dirt with it. A bit like a pumice stone.
