Best thing to clean rims
KneesUp
My braking perfomance isn't great, and I thought it might help if I cleaned the rims a bit.
I've read that Surgical Spirit is the nest thing to use, but all they had in my local supermarket was some sort of surgical spirit / eucalyptus oil hybrid, which obviously would be no good for a braking surface.
Are there any other recommened products, or do I just need to get to a proper chemist? When you watch those 'Your house is filthy you weirdo' type prgrams they clean everything with with either vinegar or bicarbonate of soda. Would either of those work well on aluminium?
Bodhbh
I use meths. It's good for cleaning rims too.
Profpointy
I've always used meths. Unlike acids or alkalis or stuff containing salt it won't hurt the alloy, and since meths isn't oily, shouldn't leave.a film.
Fubar
Going round the rims with wipes (baby, kitchen, etc) after each ride in the winter helps to keep your wheels in good condition and should lessen wear on the brakes - give the brakes a good going over as well, preferably with the wheels off. Good opportunity to check the tyres for foreign objects too.
e-rider
Banned member
South West
meths is best
helston90
Eat, sleep, ride, repeat.
Cornwall
Yep another vote for the occasional wipe down with meths too- try not to get it on the tyres though, don't think it does it much good.
Loch side.
Soap and water and steel wool. Also remove all the embedded aluminium in your brake blocks This will show up as white or shiny spots if you use a torch to illuminate that area.
KneesUp
KneesUp
Isopropyl alcohol is a lot better and less minging than meths or white spirit.
I used to buy that in Boots to clean cassette heads and capstan rollers. I thought chemists weren't allowed to sell it now though?
