PoweredByVeg
- Lingwood/Norwich
+1 for Lezyne, flexible hose reduces stress on valve and they're well engineered
If you are going to carry the pump on the bike, you might as well get a full-sized one: the point of a mini-pump is that it will fit in the pocket of your jersey.Hi Guys,
Can you make some recommendations for a pump to carry on the bike?
I've looked at the Co2 pumps, but then I read that most people prefer to use a good mini pump which would be able to get to 110 psi easily?
Thanks.
No mini-pump will reach 110 psi "easily": even the ones which can actually get that much pressure in a tube (as opposed to the ones that claim to) will take something like thirty more strokes than a full-sized one and as you get close to 100 psi they will all require some effort.
Incidentally, the gauges found on pumps aren't terribly accurate as they measure the pressure between the valve and the pump, rather than what is in the tube; if it's important to you, then you need an independent gauge that attaches directly to the valve.
