thefensman
- HARTLEPOOL. NORTHEAST ENGLAND
Hi lumix, I have just started using "bike hub app" on my android and it does everything I need. As easy as a car satnav to use, simply enter start location then where you wish to go, press "cycle route" and your off. You can put in as much or as little info as you want ie places of interest along route, shortest, quickest, flatest route etc. It will even plot you a circular route which I have used a couple of times from my house around a 40 mile ride and then back and never on same road twice. It can be used as conventional satnav as I say but maps can be peloaded before your ride which apparently uses less battery, however as i,ve said previously i,ve not had any problems with battery life while using this app, i,ve simply made sure phone had a full charge before I set off. Also has voice prompt via head phones if needed. May not be for you but give it a look.
