Belt drive gravel/hybrid bike advice
Slick
Thanks for the advice folks.
As far as maintenance goes, I know a couple of places locally who can service so covered there.
That Spot bike looks good but I don't fancy dealing with import charges so think thats out.
It looks like I could get a new Shand bike which is essentially the Leveret but with the fork from the Stooshie. Its a bit over budget - £2500
Other options are the Canyon Commuter 7 (£1750), the Bad Boy 1 (£2000), or Cube Editor (£1800).
Of these, any opinions?
I reckon they are all fairly well priced as that would be my order of preference from most expensive down.
Sake, I'm turning into Mrs Slick. :laugh:
The Bad Boy 1 can often be got new for £1,800 or less. Personally I like things that are a little different so that would be my choice. It does only come in black so that might put some people off.
P
pezmm
Member
Me too, it appeals to me!
Just looking at the gearing range of the Alfine 8, found a website that said the gear ratio ranges from 0.527 to 1.615. I'm struggling to relate that to my current bike which is a really old Ridgeback with 3x8 gears. Is the overall range likely to be similar?
I looked at something similar a few years ago and had an Excel spreadsheet to work out the gear inch range compared to my other bikes as I found that easiest to get the best comparison with something I know.
Along with the Alfine 8 gear ratios you need to factor in the number of teeth on the front and rear of the drivetrain and the diameter of the wheels.
I had an Alfine 8 equipped bike for a while, the easiest way to change the ratios is swapping out the rear sprocket, Shimano make a range of sprockets to suit.
