gavroche
Getting old but not past it
- North Wales
And then, there is also "crossing the chain" , but that's for later.
On a gripshift (right hand side, rear gears), gear 1 is the lowest gear which corresponds to the largest cog at the back.
You have it the wrong way round. 1 is the smallest and 7 is the largest on the rear gears. As you twist the shifter back towards you it winds the cable in and goes up the rear cassette or front chainset
View: https://youtu.be/InRzlEuxxF0
So 1 is the fastest gear in the rear? Really?
Basically you want to keep the line from front to back cogs fairly straight. So 1 front and 1 back, or 3 front and 7 back are good, but 1 at the front going diagonally to 7 at the back is bad and the reverse).
When I first got my 7 speed bike the guy in the shop told me it was approximately 1 front with 1-4 at the back (uphill), 2 at the front with 2-5 at the back (normal), and 3 front with 4-7 at the back(going fast not expecting to stop). And when you are intending to stop you shouldn't stop in those "fast" gears as it is hard to get started in them.
Honestly I struggled myself when I first started.
