I've spent a good couple of hours over the last couple of nights trying to set up my BB7 road brakes, and I just can't get them so that I'm happy with them. I'm actually at the point where I'm beginning to fear that my commuter bike might never get built up again, and I may just take up tiddlywinks instead.
I've followed the paper instructions, then given up and followed the youtube instructions (which were a lot better), I've tried with the bike on the stand, with it upside down, I haven't yet tried it underwater, but I'm watching a couple of scuba sets on ebay.
The main principle is to ensure the cable isn't attached and then centre the disc in the caliper. This is done by tightening the inner and outer dials while the bolts attaching the caliper to the frame are loose, then when everything is taught and the disc is in the correct position tighten them. You merely then need to slack off the dials a few clicks, tighten the cable and voila!
Yeah right.
It's a simple process but I'm always getting rotor scrape on the outer pad. Even when I dial it out completely it still happens. I then have to have another go at moving the caliper so that it's closer to the other side and everything goes wonky again.
On a couple of ocassions I have managed to get the rotor spinning through without any scrape on the pads, but then the amount of play on the brake lever is silly. I want to feel like a small squeeze is all I need to engage stopping procedures, but it's to the point where the gear shifter behind the brake lever is getting wedged on the bars it's so slack.
The only way I can reduce the slack is to shorten the distance the lever arm on the caliper has to travel, but that inevitably causes more scrape on the rotor and the youtube video seemed to suggest that I shouldn't have to move it that much.
Please (for the love of god), does anybody have any advice or knowledge on this, or any magical solutions?
Yeah right.
