So here is the issue,
Trying to find the source of an annoying click, pulled out the crankset as usual and found that the drive side bearing felt a bit gritty. Obviously time to think about replacing.
So would you reccomend getting the tools and a press and sorting it myself or would you just pay the lbs to do it?
Also, the bike has done about two thousand miles from new, mostly dry, and I have take. The crankset out and cleaned it regularly. Is this about the expected life for a set of BB30 bearings? If so I might as well buy the tools.
