JtB
Prepare a way for the Lord
- North Hampshire
I doubt the axel is broken since I've had this problem ever since the bike was delivered new 2 months ago.
The following pictures were taken of the rear wheel alignment after my last ride. On previous rides, whenever the rear wheel went out of alignment I would realign the wheel such that it was sat tight in the drop outs. However, after another mile or so the wheel would always go back out of alignment again and I'd end up having to repeat this procedure many times during a single ride. However, on my last ride, when the rear wheel went out of alignment, instead of realigning the wheel, I realigned the brake calipers instead. This alignment is what is shown in the following pictures:
This shows the quick release lever on the left hand side of the bike.
This shows the brake alignment which is good.
This shows the other end of quick release on the right hand side of the bike.
After taking the above pictures, I then removed and replaced the rear wheel again (sitting it tight in the drop outs) and tightened the quick release lever. The resulting alignment is what is shown in the following pictures:
This shows the brake alignment which is bad.
In the above picture I backed the brake pads right off and you can see the disc is still rubbing on the left hand side of the caliper (note: before I started tightening the quick release lever, the brake alignment was good, but as I started to tighten it, the rear part of the cycle frame started to flex inwards and that seemed put the brake out of alignment). My only option now (after having removed and replaced the rear wheel) is to re-align the brake caliper again, but previous experience with this bike has shown that it will be out of alignment again after another mile or so.
After taking the above pictures I then removed the skewer and took the following pictures:
This shows the axel on the left hand side of the bike.
This also shows the axel on the left hand side of the bike (with the bike upside down).
This shows the axel on the right hand side of the bike (with the bike upside down).
This shows the loosened skewer on the left hand side of the bike (with the bike upside down).
This shows the loosened skewer on the right hand side of the bike (with the bike upside down).
I don't know if the above pictures help or not.
Many thanks all,
Shaun.
Many thanks all,
Shaun.
